Rulers not shown
Rulers not shown
Post by andrew » Fri Oct 21, 2016 3:36 pm
From a QCAD user:
Edit > Application Preferences > Graphics View > Appearance > Show Rulers does not appear to have any effect. How can I enable the rulers?
Re: Rulers not shown
Post by andrew » Fri Oct 21, 2016 3:37 pm
Please try restarting QCAD after switching rulers on. If you cannot fix the problem, you might want to reset the QCAD configuration by deleting QCAD3.ini:
http://www.qcad.org/rsforum/viewtopic.php?f=47&t=3325
Cav1313
Post by Cav1313 » Tue Feb 27, 2018 11:26 am
I have the same problem with QCAD Professional (Trial Version), but on a Mac, so the .ini workaround, presumably, is not an option.
Ken
Post by andrew » Tue Feb 27, 2018 11:30 am
Please do click on the link posted above. It also contains a solution for macOS.
Cav1313
Post by Cav1313 » Wed Feb 28, 2018 11:52 am
Many thanks for that Andrew, it worked like a charm.
Had no idea that .ini was used outside of Windows.
Ken
