"Can not open file Please check your access rights, file format, and file extensions"
ldub
Post by ldub » Sat Aug 11, 2018 3:17 am
I sent a couple of files to some and they are receiving the error "Can not open file Please check your access rights, file format, and file extensions".
QCAD version 3.1.1.0 (3.1.1)
MacOS 10.13
The other user is using
QCAD 3.0
MacOS 10.12
Dining Tent.dxf
(159.25 KiB) Downloaded 342 times
Re: "Can not open file Please check your access rights, file format, and file extensions"
Post by Husky » Sat Aug 11, 2018 4:18 am
I've no trouble to open that file with QCAD Pro or the current QCAD CE edition on a Win10 OS.
Post by andrew » Mon Aug 13, 2018 10:30 am
QCAD 3.0
Please make sure that you are using a file format version that is supported by both versions of QCAD. QCAD 3.0 supports DXF/DWG up to version 2010.
