[solved] Not all entities shown while moving
Post by andrew » Fri Feb 17, 2023 5:36 pm
From a QCAD user:
When I try to move things on the drawing parts of the items I am trying to move disappear. How can I change that?
Re: Not all entities shown while moving
Post by andrew » Fri Feb 17, 2023 5:38 pm
QCAD does not preview all entities for performance reasons.
You can adjust the maximum number of preview entities under:
Edit > Application Preferences > Graphics View > Appearance > Display and Performance > Number of preview entities
newyd_cnc
Re: [solved] Not all entities shown while moving
Post by newyd_cnc » Wed Mar 20, 2024 8:20 pm
Hello, in my case if increased "Number of preview entities" to 1000 but I can still see one only entity as I move a series of selected entities (roughly 20 objets seleced simultaneously) .
What am I doing wrong?
Thank you
Post by CVH » Thu Mar 21, 2024 5:37 am
newyd_cnc,
To answer that better we would need an example drawing file.
(Also see above forum rules in red)
Presuming complex shapes as those are omitted on preview.
Or complex Blocks, Hatches, ...
Or 3D entities
Or ...
newyd_cnc
Post by newyd_cnc » Tue Mar 26, 2024 8:15 am
Thank you for our help, I am sorry for not posting a screenshot before.
The selction includes : 5 lines, 2 splines, 5 arcs and 2 circles. When I move the lot, only one of the splines is offered to preview. Number of preview entities is 1000. It would be much more helpful in my case to preview the whole object, as I am manually nesting shapes
Post by CVH » Tue Mar 26, 2024 8:39 am
This falls under 'Complex Shapes'.
QCAD figures out the complexity of the selection and when true the preview is limited.
One would then ask why that one spline and why not the Lines-Arcs-Circles ... The less complex drawing entities.
This has probably to do with the order of things ... The spline ID is probably the first in the selection array.
The order of a selection can be seemingly arbitrary.
I have seen ID arrays in different order from simply TA in the same drawing.
All depends if the array is used as is or ordered front to back or back to front after querying.
