QCAD 3 on Debian 7 "wheezy" 64bit
Post your question about installing or upgrading QCAD version 3
Postby ralvejd » Sat Aug 18, 2012 12:44 am
Hi
I've managed to run qcad 3.0 on Debian 7 "wheezy" 64bit
I rewrote the script qcad
It could probably be made much neater, I'm pretty bad at bash script :oops:
Note the path, change to that of your installation
cd /opt/qcad-3.0.0-prof-linux
#!/bin/bash
# QCAD startup script
# ralvejd special
export LD_LIBRARY_PATH="`pwd`:$LD_LIBRARY_PATH"
./qcad-bin -style plastique
I also installed the ia32-libs
:D
ralvejd
Re: QCAD 3 on Debian 7 "wheezy" 64bit
Postby spatz » Sat Aug 18, 2012 5:56 pm
Hello ralvejd,
Thank you for sharing your script. It solved my problems on the same OS (Debian "wheezy", but 32bit) and saved me a lot of time.
Best regards
spatz
spatz
Return to QCAD 3 Installation and Upgrades
