QCAD 3 on Archlinux 3, 64bit
Post your question about installing or upgrading QCAD version 3
Postby andrew » Mon Sep 24, 2012 3:32 pm
From a QCAD user:
I am using Archlinux 64 bits, my kernel version is 3.5.4-1-ARCH.
When I go into the qcad extracted folder, and do
./qcad
Here is what I get:
./qcad: line 38: ./qcad-bin: No such file or directory
Same reply when I try to open qcad-bin directly.
Re: QCAD 3 on Archlinux 3, 64bit
Postby andrew » Mon Sep 24, 2012 3:33 pm
On 64bit Linux systems, you will have to install 32bit compatibility libraries to run QCAD. Most 64bit Linux distributions have one single package you need to install to provide 32bit compatibility, usually called "ia32-libs". Archlinux seems to offer a similar way which is described in detail on the Archlinux web site at:
https://wiki.archlinux.org/index.php/Us ... _on_Arch64
You will most likely only need these two pieces of information:
QT-Applications
Programs using QT should run at once after installing lib32-qt.
Library paths without having them in /etc/ld.so.conf
LD_LIBRARY_PATH="/opt/lib32/usr/lib/:/opt/lib32/lib/:$LD_LIBRARY_PATH"
Return to QCAD 3 Installation and Upgrades
