[solved] qcad-3.1.2-pro-linux-x86_64 - Debian Squeeze 6.0.7
tyler durden
Postby tyler durden » Tue Jun 25, 2013 11:50 pm
I guess it's mainly my fault to have not upgraded to Debian/Gnu Linux Wheezy 7 yet...
tyler@squeeze64:~/qcad-3.1.2-pro-linux-x86_64$ ./qcad
Answer :
./qcad-bin: /lib/libc.so.6: version `GLIBC_2.14' not found (required by ./qcad-bin)
./qcad-bin: /lib/libc.so.6: version `GLIBC_2.15' not found (required by ./libQtGui.so.4)
With many others kind of not found relative to GLIBC_2.14 or GLIBC_2.15 and ./libqcadsnap.so, ./libQtGui.so.4
Any chance i can run it under Squeeze or i must prepare my upgrade ?
I run the binary from the download section of my account found in the qcad-3.1.2-pro-linux-x86_64.tar.gz
Best.
Re: qcad-3.1.2-pro-linux-x86_64 - Debian Squeeze 6.0.7 - GLI
Postby andrew » Wed Jul 03, 2013 12:11 pm
Please check if the new QCAD 3.1.3 fixes this problem:
viewtopic.php?f=16&t=2475
tyler durden
Postby tyler durden » Wed Jul 03, 2013 9:03 pm
It work perfectly.
Thank you very much. Thanks to you i can be lazy a little bit more and postpone my Debian/Gnu linux Squeeze upgrade to Wheezy - i know it's bad....
By the way what are the differences between 3.1.3 and 3.1.4 ? (the time i get back to my production computer i've seen the change of version)
Merci encore, à bientôt.
Best.
Postby Clive » Thu Jul 04, 2013 9:14 am
tyler durden wrote:By the way what are the differences between 3.1.3 and 3.1.4 ? (the time i get back to my production computer i've seen the change of version)
Please refer to the change-log for details:
http://www.qcad.org/en/qcad-documentati ... -changelog
tyler durden
Postby tyler durden » Thu Jul 04, 2013 9:06 pm
Thank you.
Best.
Return to “QCAD 3 Installation and Upgrades”
