Mac OS and themes
petevick
Mac OS and themes
Post by petevick » Wed Dec 08, 2021 9:25 pm
Would I be correct in saying that all versions of Qcad for all Mac OS versions do not support themes, or are there older versions of Qcad that do support themes in the Mac OS. If there are older versions, what might be the latest version :?:
Pete Vickerstaff
Re: Mac OS and themes
Post by andrew » Wed Dec 08, 2021 10:47 pm
Themes were included in older versions but broken. That's why they are no longer present in newer versions. In other words, themes never worked as expected on macOS.
petevick
Post by petevick » Wed Dec 08, 2021 11:04 pm
Thanks for the reply Andrew.
The reason I ask is because after a lot of effort I've managed to create a macOS in a VirtualBox VM, the aim was to see if I could get a theme to work with macOS, and I'd hate to see all that effort go to waste, so what was the last version that supported themes?
Pete Vickerstaff
Post by andrew » Wed Dec 08, 2021 11:34 pm
You can proceed as follows:
- Install the latest version of QCAD
- Copy the "themes" folder to your app bundle to QCAD-Pro.app/Contents/resources/themes
- Add the following line to your ~/.config/QCAD3.ini:
[Theme]
ThemeName=Coffee
Or whatever theme you want to test.
- Start QCAD
- Use Misc > Development > Run Script to run the attached script file to apply the theme.
applytheme_mac.js
(1.48 KiB) Downloaded 468 times
petevick
Post by petevick » Thu Dec 09, 2021 7:25 am
Thanks for that Andrew, I appreciate it.
Pete Vickerstaff
