Install add-ons to community edition
leetschi
Post by leetschi » Tue Mar 15, 2022 6:06 pm
Hello dear QCAD users
I'm running EndevourOS which is based on Arch Linux. Therefore It's possible to download QCAD from the arch repository. Also, I bought the professional edition.
But installing the pro version on my Xfce desktop environment didn't go well with theming. And the fonts are to small.
What I would like to know is, if it is possible to copy the plugins that are lying in my /user/name/opt folder to the app that I installed from the arch repository.
So this way I can have the pro features from QCAD on the arch repository app and the advantages of a repository ...
Re: Install add-ons to community edition
Post by andrew » Tue Mar 15, 2022 6:15 pm
No, this will very likely not work (the Qt version and configuration have to match exactly for the plugins to load).
Can you post a screenshot?
There are ways to adjust the font sizes, etc.
You could also try to use the system's Qt installation instead of the one that comes with QCAD.
leetschi
Post by leetschi » Tue Mar 15, 2022 8:39 pm
Hello Andrew
Her's the screenshot from the arch repository version:
And here from the pro version:
I'm on arch linux QCAD version 3.27.1.6 from arch repo
QCAD pro ist version 3.27.1.0
Post by andrew » Tue Mar 15, 2022 9:37 pm
It's hard to tell how big / small that is as I don't know your screen size. If it's really small, Qt might not be able to detect your high-res display and you might want to adjust the user interface scale to 2 under:
Edit > Application Preferences > General > User Interface > Scale factor
The menu font can also be adjusted separately under:
Edit > Application Preferences > Widgets > Menu Bar > Font size
As for themes, your distribution likely comes with custom Qt libraries or Qt plugins. QCAD Professional is compiled to run across a wide range of Linux systems, I wouldn't expect it to respect the theme of your distribution. You can try to remove the Qt libraries of your QCAD Professional installation to force QCAD to use the Qt libraries of your system. This might or might not work.
leetschi
Post by leetschi » Tue Mar 15, 2022 10:24 pm
Thank you Andrew this helped a lot, forgot about the customizability of Qt apps!
Greetings from our same wonderful country :-)
