Round multiple corners
Postby Tomtefar » Wed Jun 30, 2010 11:11 am
I've got a lot of lines that are connected at 90 degrees and would like to round the corners at all connections. Is that possible to accomplish without manually clicking on every entity?
Edit: Found out how to do it in Autocad: Draw the lines as Polylines and then apply the command FILLET on polyline with the appropriate radius. This feature doesn't seems to be implementet in qcad, am I right? If not, will it perhaps be soon?
Tomtefar
Re: Round multiple corners
Postby Z.K. » Thu Sep 22, 2011 1:24 am
Tomtefar wrote:I've got a lot of lines that are connected at 90 degrees and would like to round the corners at all connections. Is that possible to accomplish without manually clicking on every entity?
Did you ever figure out how to do the fillet(rounded corners) in qcad?
Z.K.
Postby andrew » Thu Sep 22, 2011 4:26 pm
I've added a feature request for this. Definitely something that is quite possible to implement in a future version:
http://www.ribbonsoft.com/bugtracker/in ... ask_id=275
