Unable to delete single points
Postby kaber » Wed Aug 03, 2011 2:09 pm
Sometims, when i draw polygon lines, there appear single points in the rawing which don't seem to belong to any line. I dont know how this can appen. I am not able to delete them. It seems not to be possible to mark them or to get any info to which object they belong. How can i proceed?
Best regards,
kaber
Postby andrew » Wed Aug 03, 2011 2:13 pm
Please indicate your QCAD version and the platform you are on.
Postby kaber » Wed Aug 03, 2011 2:23 pm
QCAD Proffesional version is 2.2.2.0, i am working on suse Linux 11.4
Best regards,
kaber
Postby andrew » Wed Aug 03, 2011 2:26 pm
If these are display errors, they will go away if you do a redraw, zoom in or out or pan.
If they are small lines, you should be able to select them using a rectangle selection.
If both is not possible, try to select all, then deselect all other entities using the appropriate selection tool.
