holes around a flange
Postby mi3gto » Thu Dec 01, 2011 7:25 am
I need to produce many flanges which have holes drilled equal distance around the flange. How do I draw a array of say 6 = distance holes. Can't even see how on V3.0 can this not be done with a simple select circle and type the number of holes and their diameter? How would you do it?
mi3gto
Postby andrew » Thu Dec 01, 2011 11:58 am
1. Draw first hole
2. Select hole
3. Modify - Rotate
4. Choose center of rotation
5. Enter angle and number of copies in rotation dialog. All inputs accept formulas as input. For example for 8 holes, enter for the number of copies '8-1' or '7' and for the angle '360/8' or '45'.
Postby mi3gto » Thu Dec 01, 2011 1:57 pm
Thank I just found it myself after playing for some time but I did not know about the fomul input great stuff thanks.
mi3gto
cron
