saving in dxf-format
Postby cadio » Fri Feb 10, 2012 10:58 pm
I`m new to this softeare and I could not find a clear answer to my qusestion: is it possible to sve a drawing to the dxf-format so that you have a file called "name.dxf", for example?
Thank You
cadio
cadio
Re: saving in dxf-format
Postby Clive » Sat Feb 11, 2012 8:33 am
cadio wrote:Hello,
Thank You
cadio
Hi and Welcome cadio
File > save as > files of type > choose dxf >name your file - e.g QCAD, then save to your location.When you save your file the extension .dxf will ba addad, e.g -QCAD.dxf
You can also click on the icons - "save" or "save as" to open up the "save drawing as" dialog window!
Hope this helps :wink:
Users browsing this forum: Yahoo [Bot] and 1 guest
