How do i list the node coordinates of a polyline?
Postby moxer » Tue Sep 18, 2007 10:19 pm
Well.. the title pretty much says it all :)
How do I draw a polyline and then get a list of all the nodes' coordinates? (the final goal is to copy that data and export it to a datasheet)
Is there a way to do the opposite? (copy 2 sets of columns from a datasheet and past them into the command line to get a polyline)
Thanks for the help :)
moxer
Postby michael » Mon Sep 24, 2007 11:52 pm
Maybe use Vector. See "vector01.qs". In QCad Professional version with Scripting.
Cut&Past to the command line does not work. As far as I know.
Do you CAD? - I do QCad.
michael
Users browsing this forum: Majestic-12 [Bot] and 1 guest
