How do I trim?? Query from a newbee
Phil Smith
Postby Phil Smith » Sun Oct 28, 2007 3:00 pm
Hi Qcaders:
I'm a Qcad newbee interested in drafting for my home cabinetry projects. Here is a question:
I made a square that is 25 x 25 and then drew a 315 degree angle from the 12.5,25 point. The angle intersects that upper right corner of the square, and extends beyond the right- side of the square.
I want to:
1. trim the upper right corner of the square that is "cut off" by the angle, and then
2. trim the segment of the angle line that extends beyond the right-side of the square.
How do I do this? I'm new to Qcad and cad in general.
Thank you!
Phil Smith
Duluth, GA
michael
Postby michael » Mon Oct 29, 2007 1:45 am
1. Use the CUT Tool. [di]
2. Cut the lines needed in parts with the scissor tool. Use [si] intersection points to match intersection lines. Then left click do the cut.
3. Then use DELETE to delete.
OR better and faster:
3. Use the TRIMM tool [d2].
Yes, [d2] is your friend here!
Check also http://www.flagsoft.ch/qcadtutorial/qcadtutorial.html for a few video online tutorials.
Do you CAD? - I do QCad.
Phil Smith
Postby Phil Smith » Mon Oct 29, 2007 2:22 am
Many thanks! Et tu d2!
Phil Smith
Duluth, GA
Phil Smith
Duluth, GA
Return to “QCAD 2.1/2.2 'How Do I' Questions”
