hatching, and scales .... ?
craigdrury
Postby craigdrury » Thu Apr 26, 2007 10:11 am
I have followed the hatching guide in the manual to the letter,...
selected a 1000x500 rectangle
selected 'earth fill'
scales from 0.001 to 1000 in x10 increments
and none of them seem to produce anything on-screen? or on the print preview...
they say hatch completed successfully? ?
what am I missing out?
Re: hatching, and scales .... ?
Postby andrew » Thu Apr 26, 2007 10:17 am
craigdrury wrote:I have followed the hatching guide in the manual to the letter,...
Please refer to the FAQ: http://www.ribbonsoft.com/qcad_doc_faq.html#11
craigdrury
Postby craigdrury » Fri Apr 27, 2007 7:35 pm
I have patchy sucess with this command...
I have turned all the layers so that they are not visible, and used the rectangle command then sometimes it says it cant find a complete contour? even though the only thing I can see is a rectangle I have just drawn on layer 0?
I can forward a file if that would help? I am using a mac under OS x 10.3.9
Craig
Users browsing this forum: Yahoo [Bot] and 1 guest
