How to move the Command line - Tip!
Postby Clive » Fri May 18, 2012 3:50 pm
Hi Guys
Sometimes its useful to gain more drawing area space - did you know you can move the command line!
To do this:
1.Simply click on the bottom 'right hand' corner button to show the Command line header (hidden by default to save a little space).
2.Then minimise the command line and drag and re-dock it in the right hand side panel.
- :wink:
Command line header button.png (25.14 KiB) Viewed 5165 times
Select here to minimise the command line.png (25.01 KiB) Viewed 5165 times
Command line re-docked to right hand side panel.png (93.38 KiB) Viewed 5165 times
Moderator / Drawing Help
Return to QCAD 3 Tips and Tutorials
