Tip - How to hide the Meta Grid
Postby Clive » Fri Mar 22, 2013 12:49 pm
Here's a little tip for hiding the Meta Grid if you so wish, you cannot remove it but you can hide it!
Go to Main menu - Edit > Application Preferences > Graphics View > Colors > Meta Grid, and in the drop down menu choose ' others' and then in the Select Color dialog window change the value in the Alpha channel to '0'.
This will effectively hide the Meta Grid.
Hide Meta Grid.png (18.47 KiB) Viewed 4856 times
Moderator / Drawing Help
Return to QCAD 3 Tips and Tutorials
Users browsing this forum: No registered users and 6 guests
cron
