Blocks
Blocks
Postby faber » Wed Mar 16, 2011 9:42 pm
I have made up a block of 1 polyline and 2 line (customized arrow).
Then I have tried to copy/paste in another drawing, but only the polyline is present (it is an arrow without tip) :(
faber
Postby faber » Sat Mar 19, 2011 2:13 pm
anybody knows why only a part of the block is being copied? (the polylines)
faber
Postby J-J » Mon Mar 21, 2011 7:08 pm
I cannot reproduce your problem, the block is copied allright. Did you select all the entities for the creation of the block?
JJ
J-J
Moderator
Postby faber » Mon Mar 21, 2011 8:05 pm
J-J wrote:I cannot reproduce your problem, the block is copied allright. Did you select all the entities for the creation of the block?
yes; if I delete the block in the original drawing everything disappear, while if I explode it I can select only one entity, if I want.
faber
