Scales
Scales
Postby luisjove » Thu Mar 17, 2011 7:49 pm
I have problems with editing function SCALES. The manual that I own is old and is not an option:
Factor X:
Factor Y:
I guess serves to scale with a factor, the X axis, and another factor (or the same) the Y axis.
I tried to enter two values ​​to test, Factor X = 2, Factor Y = 1, and does not work.
Is it that I am using this function wrong?
Thanks and regards,
Luis Jove.
luisjove
Postby andrew » Thu Mar 17, 2011 7:52 pm
Please note that non-proportional scaling only works for line entities at this point. Arcs and circles are not converted to ellipse arcs and ellipses, text cannot be 'squeezed' together, etc.
Postby luisjove » Thu Mar 17, 2011 8:57 pm
Andrew,
I understand.
Greetings and thank you very much,
Luis.
Understood
luisjove
Users browsing this forum: Google [Bot] and 1 guest
