coloured text not being retained after blocks created
bluequad
Postby bluequad » Wed Jun 22, 2011 11:47 am
Windows Vista Premium with QCAD version 2.2.2.1
Whem making drawing sheet templates, different coloured text is not saved when the block is created after inserting it back into the main drawing. It appears to revert all lines and text to the base layer information.
Also some elements when scaled up simply disappear when recalling the block..
Any suggestions?
