Visibility of block
VOK
Visibility of block
Postby VOK » Sun Jul 03, 2011 11:40 am
I am unable to successfully change the visibility of a block that contains text. I have toggled the visibility to off, however the program is still able to select an intersection point of the components of the text even though they cannot be seen. I have tried setting the text to a separate layer, and disabled this layer, this was also unsuccessful
I am using QCad 2.2.2.0 on Windows 7 64
Users browsing this forum: Google [Bot] and 1 guest
