unable to save - Exception occured. Entity NOT saved: 167
Postby JSElabs » Tue Jan 03, 2012 1:20 am
I just downloaded the new QCAD and am having trouble saving. When I try to save as any format I get a error
While it does seem to save a portion of the file, it removes all layers and is not editable.
I am also wondering if it might be possible to export a window or layout rather than the set page scaling.
On a totally different note, the exception error is spelled wrong. "Occured" is actually spelled "Occurred".
JSElabs
Postby andrew » Tue Jan 03, 2012 8:52 pm
Does this happen with QCAD 2.2 or rather with a QCAD 3 release candidate (in the later case, which one)?
If you are using QCAD 3 RC2 (Mac, Linux) or QCAD 3 RC3 (Windows), please issue a bug report through our bug tracker and attach the file if possible or send the file by e-mail.
Bug tracker:
http://www.ribbonsoft.com/bugtracker/in ... &project=1
