QCAD hang
QCAD hang
Postby mr.rigg » Thu Jan 19, 2012 4:17 pm
32b,Win7, QCAD2.2.2.0.
Can not use drop down FILE menu to SAVE, SAVE AS, or OPEN, PC hangs up. Please advise.
mr.rigg
Re: QCAD hang
Postby Clive » Thu Jan 19, 2012 7:53 pm
mr.rigg wrote:32b,Win7, QCAD2.2.2.0.
mr.rigg
Hi and Welcome to the forum
Can you use any other menu options e.g. View or Edit or any Tool commands without problems?
If this is first time install, if it was me I think I would try a re-install and try a different directory!
See if that works.
Left mouse button without function.
Postby Werner Schulte-Derne » Mon Jan 30, 2012 6:04 pm
32b, Win7, QCAD 2.2.2.1
Same problem occurs with my installation. Left mouse button seems to be without function. Drop down menues are working only by using Alt and any keyboard click. I tried reinstall in a different directory, but without success.
Werner
Postby Clive » Mon Jan 30, 2012 7:52 pm
Hi Werner Schulte-Derne
Re: " Left mouse button seems to be without function "
Could it be a configuration issue with your mouse?
