[SOLVED] Can't move toolbar
Postby paulcoyote » Thu Jun 07, 2012 6:49 pm
Hi:
I've moved the main toolbar out of the screen (in a 1440x900 resolution) and can't get it back to its place, the left handler is out of the screen and can't be accessed by the pointer. Please take a look at this creen:
I'm using Ubuntu 10.04 Qcad PRO 2.2.2.0
Out of the screen toolbar
Any idea? There is a configuration file or so?
Thanks in advance
Paul
paulcoyote
Re: Can't move toolbar
Postby andrew » Thu Jun 07, 2012 7:30 pm
- Quit QCAD
- Reset the configuration by deleting or moving away / renaming the file ~/.config/RibbonSoft/QCAD.ini
- Start QCAD again
Postby paulcoyote » Thu Jun 07, 2012 9:22 pm
andrew wrote:- Quit QCAD
- Start QCAD again
Thanks a lot! I't was driving me crazy for a week.
Again, million thanks
Gracias!
Paul
paulcoyote
Users browsing this forum: Yahoo [Bot] and 1 guest
