Dimensions all show %, -1f
Locked
RayArdia
Post by RayArdia » Tue Oct 02, 2012 7:49 pm
Using ver 2.2.2.0 on Ubuntu 12.04.
Dimensions show their normal arrows etc but instead of the actual dim (in mm) they all show ' %, 1f'.
Re: Dimensions all show %, -1f
Post by andrew » Tue Oct 02, 2012 7:59 pm
Thanks for your report.
Please submit some follow-up information, to help us understand the problem:
Is this the case for newly created dimensions also or only for dimensions loaded from an existing file?
Was the file created with another CAD application?
What does the property editor show as property 'label' for such a dimension?
If this report applies to a particular file only, please attach or e-mail that file if possible.
Thanks.
RayArdia
Post by RayArdia » Tue Oct 02, 2012 8:26 pm
1.Is this the case for newly created dimensions also or only for dimensions loaded from an existing file?
For newly created dimensions. The file had no existing dimensions.
2.Was the file created with another CAD application? Yes, with LibreCAD.
3.What does the property editor show as property 'label' for such a dimension? Not sure what you mean by this, sorry!
4.If this report applies to a particular file only, please attach or e-mail that file if possible. File added.
Rabbit Hutch Details.dxf
(43.19 KiB) Downloaded 1204 times
Moderator
Post by Clive » Tue Oct 02, 2012 9:25 pm
RayArdia wrote:3.What does the property editor show as property 'label' for such a dimension? Not sure what you mean by this, sorry!
Ray
To show the property Editor go to - View - Toolbars - property Editor
QCAD 2 View -Toolbars - property Editor.png (74.12 KiB) Viewed 35797 times
This should 'dock' the property Editor on the right hand side of your window, when you highlight an entity (dimension in this case) the details will show in the property editor!
QCAD 2 Property Editor.png (71 KiB) Viewed 35797 times
Moderator
Post by Clive » Tue Oct 02, 2012 9:36 pm
[Edit: Updated test]
Ray
I`ve opened up your file in QCAD 2 and QCAD 3 and 2 other cad programs that I have access to at work and they have all correctly imported the same details ( %, -1f) from the file you attached.
QCAD 2
If I continue to work in the same/current drawing, yes agreed adding dimensions is a problem and gives the result that you have spoken about!
* However working on a new drawing in QCAD 2 gives no problems with dimensions.
QCAD 3/ other 2 cad programs
Working in the same current drawing - I get no problems adding new dimensions.
Post by Husky » Tue Oct 02, 2012 9:46 pm
@ Clive - I agree. And it has nothing to do with the OS - same behavior with windows ...
Work around:
Open this particular drawing in 2.2.2.
Select the entirety drawing and copy it into the clipboard.
Open a new drawing and paste this drawing.
Maybe you have now to adjust the Text size etc. but the big problem is vanished .... :wink:
Moderator
Post by Clive » Tue Oct 02, 2012 10:13 pm
Yes that`s what I found too, I suspect the problem lies with the initial imported file somehow!
RayArdia
Post by RayArdia » Tue Oct 02, 2012 10:35 pm
Thanks to you all for your help. The copying/pasting works fine, as you say some adjustments to fonts etc needed,but it WORKS :)
Post by Husky » Tue Oct 02, 2012 11:05 pm
Glad to hear that! :D
Locked
