laser cut - Celtic Knot
About the creation of DXF / DWG part library items.
Postby Clive » Sat Jun 30, 2012 5:58 pm
Hi Guys
I`ve been thinking about my Celtic roots lately with a project I`ve been working on and as such I have attached a little Knot, which you can laser cut if you so wish to!
You can edit the Knot to suit your own needs.
Just hope it doesn`t send you too 'Knotty' :wink:
[Edit: Line weights should be 0.00mm not 0.01mm]
laser cut - celtic Knot.dxf
(72.44 KiB) Downloaded 354 times
laser cut - Celtic knot.png (63.33 KiB) Viewed 5240 times
Return to Creating DXF/DWG items
