Medieval theme -Draughts/Checkers board game
About the creation of DXF / DWG part library items.
Postby Clive » Wed Apr 03, 2013 4:18 pm
Following on with my medieval theme, I thought it would be interseting to design a Draughts/Checkers board game with this in mind.
So, with dedicated supervision from my son :roll: , I have designed the game with a difference - basically each player has a choice of either a 'Sword' counter or a 'Shield' counter to play with and the game is played using the Castle squares only!
I used 2mm MDF to laser cut the game out and added an extra 2mm laminate onto the base and counters - hence the extra pieces in the dxf file.
Draughts set - medieval theme.dxf
(1.31 MiB) Downloaded 211 times
Draughts, Checkers board game.png (6.69 KiB) Viewed 3380 times
Here is a close-up of the board and counter detail.
Draughts, Checkers close up shot.png (4.42 KiB) Viewed 3380 times
Have fun :wink:
Moderator / Drawing Help
Return to Creating DXF/DWG items
