Select Widget by smf
About the creation of script items.
Postby clive » Sat Aug 25, 2012 3:21 pm
I was so impressed by this little 'Select widget' submitted by smf I just had to highlight it (hope you don`t mind Stefan).
Very often I need to select only one type of entity and modify them and this widget has been so very useful :wink:
To try out smf`s widget please download the zip file and copy/paste all files in qcad/scripts/MyTools/SelectWidget where "qcad/scripts" are the original folders and "MyTools" is an arbitrary name, "SelectWidget" is fixed.
SelectWidget.zip
(13.14 KiB) Downloaded 162 times
Select widget test 1.png (90.2 KiB) Viewed 1726 times
Select widget test 2.png (117.59 KiB) Viewed 1726 times
Select widget test 3.png (87.15 KiB) Viewed 1726 times
clive
Re: Select Widget by smf
Postby smf » Sun Sep 16, 2012 11:11 pm
Thank you so much for the illustrated tutorial :) and your kind words :D - and sorry for the late answer, I was offline some time...
smf
Return to Creating script items
