Mention the difference between an object and a class ?
ritu30
Post by ritu30 » Fri Jun 17, 2016 11:24 am
hello all i am new in the scala programming pls tell me about that stuff i am a beginner ...
thanks in advance
Re: Mention the difference between an object and a class ?
Post by andrew » Fri Jun 17, 2016 12:40 pm
The script language used in QCAD is ECMAScript (better known as JavaScript). There are plenty of resources on the web to learn JavaScript:
https://www.google.com/search?q=learn%20javascript
