Greetings from Canada
I'm semi-retired developer with around 30 years of experience. I started out as a board draftsman and then the company I was working for purchased AutoCAD version 9.0 and I was hooked. I learned all I could and began developing scripts in AutoLISP to be more efficient. After 12 years I started doing corporate development and then went into management.
I wanted to get back into CAD drafting/development so I started looking for something other than AutoCAD and found QCAD. It's an amazing product! I've since then developed a few scripts. Here's a few I've done so far:
Layer Manager - Creates layers from a SQLite database utilizing the AIA CAD Layer Guidelines
Tablet Grid - Inserts blocks, runs script blocks, scripts, commands, or other tables from an 8x8 grid tablet.
HVAC Ductwork - Draws double-line ductwork
Structural Shapes - Draws AISC W, S, M, HP, C, MC, WT, ST, MT, angles, rectangular and round HSS shapes from XML data sources
Piping Symbols - Inserts pipe fitting symbols that automatically breaks the lines, and if in isometric view, inserts an isometric version of the block with correct angle and horizontal flip
Architectural Doors and Windows - Script blocks that creates doors and windows
Isometric Circles - Draws isometric circles based on the current isometric projection
I've attached some pictures so you can get a better idea of what these tools look like.
I hope QCAD continues to succeed and looking forward to see what upgrades there'll be in the future
- View showing a piping tablet loaded
- piping tablet.jpg (41.49 KiB) Viewed 14532 times
- View showing the Layer Manager Templates tab
- layer manager - templates.jpg (40.26 KiB) Viewed 14532 times
- View showing the Layer Manager Layer tab
- layer manager - layer.jpg (45.38 KiB) Viewed 14532 times
- View showing an HVAC ductwork tablet loaded
- hvac tablet.jpg (43.27 KiB) Viewed 14532 times
- ryancousins
Re: Greetings from Canada
Welcome to the forum, MikeJ.
It looks like you really know your way around scripting! I really like the AIA layer guide.
I look forward to seeing what other tools you might develop.
- petevick
Hi Mike and welcome to the Qcad forum.MikeJ wrote: ↑Mon May 16, 2022 8:29 pmLayer Manager - Creates layers from a SQLite database utilizing the AIA CAD Layer Guidelines
All of your tools look very interesting indeed, have you considered sharing them with the Qcad community ?? I'm sure there are quite a few users that would find them very useful.
I too did a lot of AutoLISP programming back in the day, but I just can't get my head around Qcads scripting environment.
Pete Vickerstaff
- ryancousins
For sure, I'll post some of my content... would be nice to have some QA done on it
Nice work, I'll 3rd that..
I also came from AutoCad.over 35years. and I'm totally hooked on Qcad now.... ..
Looking forward to downloading your scripts and trying them out.
Hi Mike,
That is some seriously nice work you have done there. Looking forward to following you on your journey here with QCAD.
I am only just starting out with it and so far it looks promising.
Ok, I've managed to complete the builds for the QCAD Utilities and created a thread in the "QCAD Programming, Script Programming and Contributing" forum.
Hope it works ok!
Hope it works ok!
I started with AutoCAD 2.6 back in 1988 and worked at process engineering for 30 years.
Equipment layouts, hydraulics, P&IDs, Tooling development, fabrication layouts and design concepts all need graphic tools and my drafting board is too cumbersome to share with remote sites.
You guys seem to have had similar experiences as I have had with Autodesk.
QCAD seems to be too good to be true, are there any glitches ?
KW-Dynamec
KW-Dynamec
LenVW - KW Area
