Qcad 2.2.2 for Fedora x86_64
Postby musicmaker » Tue Jun 02, 2009 7:39 pm
I ordered the Qcad cd, but the only Linux install on it is for 32 bit machines, and I've got a 64 bit Thinkpad, with Fedora 10 installed.
Is there a 2.2.2 Qcad for 64 bit Linux available?
Judy Hawkins
musicmaker
Re: Qcad 2.2.2 for Fedora x86_64
Postby andrew » Tue Jun 02, 2009 7:52 pm
musicmaker wrote:Is there a 2.2.2 Qcad for 64 bit Linux available?
No, but you should be able to run QCAD 32bit on a 64bit machine with the necessary compatibility library packages installed.
Postby musicmaker » Wed Jun 03, 2009 9:32 pm
This was the original error message:
$ ./qcad
bash: ./qcad: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
The solution, boiled down from a long iterative process of consulting the net, installing the next thing, reading the error message, and consulting the net:
yum install glibc.i686
yum install libXext.i386
yum install libSM-1.1.0-2.fc10.i386
yum install libXi-1.1.3-4.fc9.i386 libXrender-0.9.4-3.fc9.i386 libXrandr-1.2.3-1.fc10.i386
yum install freetype.i386 fontconfig-2.6.0-3.fc10.i386
One of the helpful things I learned along the way was that I can use
yum to look for individual libraries IN packages:
yum provides ld-linux.so
which gives me a selection of packages to choose from. The post I
found most useful was this:
http://www.nabble.com/what-package-will ... 41229.html
Judy Hawkins
musicmaker
Return to QCAD 2.1/2.2 Installation and Upgrades
