hatching
Post here to ask questions about or get help with the scripting module of QCAD 2.1/2.2.
hatching
Postby hcore » Mon Nov 19, 2007 5:23 am
is there or will there be a way to do hatching with a script?
hcore
Postby michael » Mon Nov 19, 2007 1:13 pm
As far as I know not right now.
For what do you need it?_
Do you CAD? - I do QCad.
michael
Postby hcore » Wed Nov 21, 2007 3:38 am
basically imagine a chess board with all the squares mixed up. I want some hatched and some blank. I guess I could have a script make the squares to be hatched first, then select all and hatch them, then another script to generate the blank squares. I was just trying to find the lazy solution.
hcore
Postby michael » Wed Nov 21, 2007 1:20 pm
You plan to do a chess game? :shock: 8)
Maybe it is possible to draw one or two templates.
Then use a script to place a drawing / block or so on a positton.
hcore wrote:basically imagine a chess board with all the squares mixed up. I want some hatched and some blank. I guess I could have a script make the squares to be hatched first, then select all and hatch them, then another script to generate the blank squares. I was just trying to find the lazy solution.
michael
Postby stan.distortion » Fri Apr 04, 2008 2:17 pm
Very stupid question but would it actually be possibly to script a chess game in qcad? And with a computer opponent?? :)
cheers
stan.distortion
Return to QCAD 2.1/2.2 Developers
