Wish list item
Post here to ask questions about or get help with the scripting module of QCAD 2.1/2.2.
Wish list item
Postby barjac » Mon Nov 17, 2008 8:03 pm
When using typed dimensions (as in parallel lines etc.) it often happens that the same dimensions are needed over and over in a drawing, but not one after the other. It would be handy to have a recently used drop down list available on the dimension box in addition to the "last entry" memory as it is now. It would speed up work and also eliminate typos when entering long numbers.
By the way I cannot praise QCad Pro enough !
IIF(!broke,fixit(.f.),fixit(.t.))
barjac
Return to QCAD 2.1/2.2 Developers
cron
