Toolpath by Layer
mechatronic
Toolpath by Layer
Post by mechatronic » Mon Nov 13, 2023 3:54 pm
Other than selecting a layer and using "Select Layer Entities", is there a way to assign a tool path to a layer?
I'm using QCAD-CAM for laser cutting, so I want to make use of layers to separate each type of cut - ie cutting, engraving etc. Traditionally, you'd have 8-16 "pens" which are configs based on power and speed of cut, which gives you the full gamut of light scoring through to nuking your way through the material.
Having to manually select objects or select via the layer to re-add etc can be quite time consuming, and sometimes a missing entity goes by. It would also dramatically reduce the workflow and amount of clicking, as I've already designed something using multiple layers to isolate the different things going on, but then having to go back in and re-group them for CAM is twice the effort. Plus sometimes you can pull the wrong object into the wrong CAM, and as it's colour coded by layer, makes it hard to pick it up!
Jon
mechatronic
Re: Toolpath by Layer
Post by mechatronic » Mon Nov 13, 2023 3:55 pm
I'll add that because it's a laser, there's virtually no tool width, so very difficult to see the CAM lines to check if something is in the right tool path set!
Post by andrew » Thu Nov 16, 2023 5:46 pm
I'm not sure what exactly you mean.
What you can do in a post processor is to add additional information to the layer. You can look at the Beamo post processor for the FLUX beamo laser cutter which adds some information to layers (see layer dialog when Beamo post processor is active).
This layer information can then be used in the post processor.
mechatronic
Post by mechatronic » Wed Nov 22, 2023 12:13 am
Yeah, the Beamo one is what I'm after.
I've had a play with it, and a brief look through as well.
As most of that appears to be implemented in writeFile - how much of the block setup needs to be done in the init? I need to have some config switches that change relative or absolute commands used, and it obviously won't work if they're declared in the init block. Is it okay to set/override them in writeFile?
Example:
Absolute
this.arcCWMove = "AA[IA],[JA],[SWEEP]" + this.separator;
Relative
this.arcCWMove = "AA[I],[J],[SWEEP]" + this.separator;
etc - there's more than often just a variable name that has to change as well. I'm assuming it's okay practice to use writeFile to override based on the config settings? Obviously I have no idea how the CAM libraries work, so it's guess work at what point those variable need to be set. I initially assumed they all had to be set in the init, but looking around others, I've seen the odd variable being overwritten in writeFile.
Also, stupid question, but any variables from the QT interface; are they available as variables within normal functions, or do I have to use registerVariable on them? I have a few config options, but unsure the correct way to declare and use them within the script code. I need access to them in writeFile, after setting them up in initConfigDialog. Based on the nearest existing code I can find, it's just an objectName used. In that other sample script, it used registerVariable (but I don't know why, as it's not being merged into the block strings?), when surely I can just get it's value to evaluate in an if statement using .getGlobalOption.
mechatronic
Post by mechatronic » Wed Nov 22, 2023 12:55 am
Looking at GCode2AxisPT.js
writeFile appears to be used to switch the value of a number of blocks, so I'll follow suit I think.
Now, it's also just confused me more regarding variables in the configDialog. Initially I thought you just do the UI mods, and the variable would be available via getGlobalOption. Also assumed there's some kind of magic going on, as the options I've set, appear to save within the CAD file and persist on close/open.
But I see this block, which appears to define it as a CAD document variable (for persistence?).
GCode2AxisPT.prototype.postInit = function(dialog) {
    var ret = CamExporterV2.prototype.postInit.call(this, dialog);
    if (this.alwaysWriteG1===true) {
        this.cadDocument.setVariable(Cam.getCurrentVariablePrefix() + "AlwaysWriteG1", true);
    return ret;
What/when is postInit called? Are UI element settings not stored in the CAD file? Is this a hang-over from an older version?
Also, the init declares and sets the default
this.alwaysWriteG1 = false;
which appears redundant and pointless, as writeFile uses this if evaluation
(this.getGlobalOption("AlwaysWriteG1", false)===true) {
and doesn't reference the declared variable. Does getGlobalOption do anything auto-magic like loading a named variable etc, or does it just return the value of the variable (I assume the second option is a default/null value) as a basic lookup function?
Post by andrew » Wed Nov 22, 2023 8:42 am
Yes, you can set up variables that don't change for one single export in your writeFile implementation before exporting.
Any variable in your JavaScript that you want to use in your output has to be registered using registerVariable:
For example:
this.registerVariable("dateTime", "DATETIME", true, "", 0);
This registers variable this.dateTime of your JavaScript to be available in the post processor output as "[DATETIME]"
Correct. Those configuration options are saved to the document as persistent document variables with the objectName of the widget being the key and its status or text etc. being the value.
E.g. you can add a line edit with objectName "MyConfigurationOption" and retrieve its value in your post processor with:
this.getGlobalOption("MyConfigurationOption", "My Default Value");
Where "MyDefault Value" should match the initial state / contents of the widget in the config dialog. This is redundant but needed since defaults need to exist even if the config dialog is never shown.
Whether you want / need to expose the configuration option as a variable to the post processor with registerVariable is up to you.
Example for a widget with objectName "MyIntValue" for an integer value with default value 7:
this.myIntValue = this.getGlobalOption("MyIntValue", 7);
this.registerVariable("myIntValue", "MYINTVALUE", true, "", 0);
Note that GCode2AxisPT is user contributed. For configuration options, Dxf.js is a good example.
mechatronic
Post by mechatronic » Wed Nov 22, 2023 12:08 pm
Thank you Andrew,
Making more sense now.
I'll have a look at DXF.js as well then.
If I'm showing a Qt menu during the writeFile process, how do I access the text stream? I'm assuming instead of returning to the inherited writeFile I call it instead, and then can show the menu. I'd like a preview text block in the menu, so need to access the text stream somehow.
Post by andrew » Tue Nov 28, 2023 6:10 pm
You can call the original writeFile and when it returns do something with the file that was written (e.g. read it and display it):
MyPost.prototype.writeFile = function(fileName) {
    CamExporterV2.prototype.writeFile.call(this, fileName);
    // check if file exists, read file and display
mechatronic
Post by mechatronic » Wed Nov 29, 2023 2:03 am
Ahh, okay... wasn't sure if easier to get text stream, but literally just read from the file and display...
Because of the way laser power is defined, following the example of Beamo, it's easier to set the power for objects on the layer. But Beamo works a bit differently as they use an SVG renderer (and appear to do most of it themselves in their own way?)
3 issues...
1) How can I change the selection of lines/arcs to be supplied to the CAM tool path, from those highlighted/selected to the contents of a layer? The cleanest solution would be to either assign a layer to a CAM tool path or in layer attributes assign a CAM tool path - with the result that the instead of manually selecting paths, that all paths on a layer are selected and used for that CAM tool path. I'm guessing I need to somehow override the function that supplies a list of paths to the CAM tool path, and give it a list derived from a layer instead?
2) I don't know how CamExporter works so unsure how during iteration through the CAM generation that I can access each line/arc's layer and in turn set that attribute back into the currently processed CAM line (I just need to prefix "SPx" for the tool). I assume just assign a new variable (add it into the string template in the init... but what would I override to add the code to get the layer options to set the variable? Is there a single path function which calls descendants (like arc, line etc), or do I have to do this for every path type?
3) I need to get a list of tools used and the feed/speed into the header - I can only think of iterating through layers/CAM tools and reading them that way. Is there anything in CamExporter I can use instead to get a list of tools used (and therefore add them to the header in writeFile), or does it not know what tools are used (ie it just calls the tool change block for each CAM toolpath)?
mechatronic
Post by mechatronic » Thu Nov 30, 2023 4:41 pm
Working blind with the Cam scripts, I'm assuming at some point I can replace the list of EntityID's being given to whatever Cam function gets called first with them.
Without Entities selected, (but always an active layer), then the buttons dim for Add Profile Toolpath.
Can I just find the active layer, or does an object from that layer need to be selected in order to get a LayerID?
Obviously need to filter and ensure "CAM" and descendent layers are excluded, but otherwise validation appears to be within the generation functions, so I just need a way of call the Add Profile Toolpath (if you re-generate a tool path without any entities/deleted them, it shows a warning in the output).
My alternative thought, is to add a "layer" drop down in the CAM Profile Toolpath dialog and then use that to select the entities, but again the buttons dim... Beauty of this approach, is that a layer is always selected, so we have something to pass forward, but the generation validation stops any later errors by catching empty list of entites.
Just really blind here, so have no idea where to start!
Post by andrew » Fri Dec 01, 2023 9:06 am
Which parts of QCAD/CAM do you actually need?
Are you planning to create tools with diameters and toolpaths with the various toolpath settings such as offset, lead in / lead out, etc?
If you don't need any of that, you might be better off just overwriting writeFile, iterate through all entities in your drawing and write them to HP/GL.
In any case, I would strongly recommend to start simple and add features one by one.
What is your context?
You could for example override writeLinearMove and write different text blocks, depending on the layer or even simply stream to the output without using text blocks:
MyPost.prototype.writeLinearMove = function() {
    var layerName = this.currentEntity.getLayerName();
    // write any kind of HP/GL code depending on layer name
    // use this.xPosition / this.yPosition / this.zPosition for the target position:
    this.write("...");
Similarly, you could override writeArcCWMove, writeArcCCWMove, writeLinearMoveZ (pen up / down or laser on / off).
There are many ways to approach this. The only thing that is fixed is writeFile(fileName) that really needs to be implemented somehow otherwise, nothing is exported.
I hope that helps.
mechatronic
Post by mechatronic » Fri Dec 01, 2023 4:43 pm
Thanks Andrew,
I don't want to replace that much functionality - this is mostly workflow optimisations. I want to be able have a tool path for all objects on a layer, rather than having to manually select them.
The best process I think is to be able to select a Layer when inside the CAM tool path window. Problem is that the buttons are hidden when there's no selection (I know that there's validation in the processing functions, so overriding this should be fine).
1) I don't know how to reference the CAM widget to change the behaviour of the Toolpath and Drill routines
2) I have already got modifications for the CAM tool path window, so I can add drop down etc accordingly.
3) I don't know how to get a list of all Layers excluding CAM (not sure if there's a programatic way of testing for name other than just testing for matching labels? likewise, how do I test for child layers of a named layer too?)
4) I don't know how to get a list of EntityID for a given Layer.
5) I don't know the function to overload to replace selected EntityID with my list of EntityIDs. I presume it's a function called by the export/regenerate paths buttons.
Post by CVH » Fri Dec 01, 2023 9:29 pm
Just one of the search matches with 'dialog'.
This doesn't change the behavior of but its how to suppress or add widgets:
https://www.qcad.org/rsforum/viewtopic. ... log#p40953
In the same linked topic:
We once discovered that for B all settings names must start with "Cam".
That way they are stored in toolpaths.
https://www.qcad.org/rsforum/viewtopic. ... 015#p39015
Classes of interest:
https://qcad.org/doc/qcad/3.0/developer ... fe26e293ea
https://qcad.org/doc/qcad/3.0/developer ... layer.html
Indeed, you need to verify/filter naming.
https://qcad.org/doc/qcad/3.0/developer ... 66b85e5e31
You are probably interested in entity id's of a filtered layer per id and on the Model_Space block.
Having the Entity id you can query it from the document;
https://qcad.org/doc/qcad/3.0/developer ... 79a957c678
or
https://qcad.org/doc/qcad/3.0/developer ... 7228980d87
The more I read about your endeavor I think that in a way you are interested in adding a variant of the 'Add Profile Toolpath' resource that selects entities on a layer and calls for the CamExporter to handle a toolpath without a selection as required by KP.
mechatronic
Post by mechatronic » Sat Dec 02, 2023 12:03 am
Thanks CVH,
I'll go through and read up.
I've figured out a few bits, but not working yet... I'll post shortly.
Yes, absolutely. Whilst I can of course use "Select Layer Entities" for a Layer, if I make any changes to the layer, it's many clicks and potentially many mistakes to update the tool path. Being able to just regenerate, and it freshly pulls every entity from a layer is great.
I could potentially have 5-10 different layers with different speeds/power, and if I've already isolated each entity to a colour coded layer, to then have to reselect all entities, and run the risk of mixing entities across layers seems added risk.
It means production can get very smart, and I can have dissimilar materials in nested layers cut on the same bed, with the machine using different tool presets for diff layers.
It would be so much easier to assign a layer to a tool path. It also means that instead of having laser presets in code (like Beamo) and configuring by Layer, that I can just have those as tools stored in a template file. As I use diff materials, I want to tweak the presets anyway, and doing it in code doesn't feel right!
So my preferred method now is to enable the "Add Profile Toolpath" button/menu options at all times. Add a "Layers" drop down on the CAM Profile Toolpath dialog, and use that as the source of entities vs it being the currently selected entities.
Post by CVH » Sat Dec 02, 2023 2:15 pm
It goes further than that ...
Regenerating toolpaths, does that require to regenerate the existent toolpaths or does that restart the process with filtering layer entities?
Further you really need to differentiate the two processes:
A) Creating toolpaths from drawing entities ... Resulting in CamEntities in toolpath blocks.
B) Creating an output from CamEntities what is in your case some specific HPGL dialect.
While Cam Export (KX) does A and then B automatically with 'Always regenerate all toolpaths before export'.
Incorporating A as a sub-process of B is as putting the cart before the horse and probably not really feasible without major tricks.
While manually selecting entities may be prone to error.
Auto selecting everything can be a mess too depending on what is in the drawing besides geometry to cut.
Blind trust in that it will always be the intended selections, and only those, may lead to dangerous situations.
Then you would blame QCAD/CAM when an accident happens.
Your automated methods must be rigorously tested, the coding itself must be so robust that it will never ever fail.
Return to “QCAD/CAM”
