Turret Punch
Turret Punch
Postby tomnowack » Wed Jul 31, 2013 3:58 am
Hello, is there a setup to use the cam add-on for turret punch g code? Kind regards Tom
tomnowack
Re: Turret Punch
Postby andrew » Wed Jul 31, 2013 11:08 am
Hello, the CAM output can be configured through a powerful JavaScript interface. If you have simple example G-Code file that shows the kind of output you need and you could post it here, I can estimate the effort it would be to create a configuration for your machine. Thanks.
Return to QCAD 3 CAM Add-On
Users browsing this forum: Yahoo [Bot] and 4 guests
