G code Directory
Discussions around the CAM Add-On of QCAD version 3
G code Directory
Postby jthornton » Sat Oct 26, 2013 3:23 pm
It looks like the default directory that the G code is saved to is the same as the CAD file. Is there a way to define a default G code directory when you save the file?
JT
jthornton
Re: G code Directory
Postby andrew » Sat Oct 26, 2013 5:07 pm
I don't think this is possible without a hack.
Personally, I tend to keep all files of a project in one folder as a portfolio (DXF, CNC, PDF, SVG, etc.). A configurable override of that behavior would certainly be possible.
Postby jthornton » Sun Oct 27, 2013 1:32 pm
I also keep project files in separate directories but all the G code files go to the machine home/~/linuxcnc/nc_files directory. Just depends on the machine or simulator I'm coding for.
What do I need to hack?
JT
jthornton
Return to QCAD 3 CAM Add-On
