QComboBox Action
jthornton
QComboBox Action
Postby jthornton » Sun Nov 17, 2013 2:45 pm
Is it possible to make a selection in a QComboBox that causes the next box to be filled with the correct choices for the selection. For example if I select the 40a nozzle then the range of material to cut is 26 ga to 14 ga. and a different nozzle would have a different range.
JT
Return to “QCAD/CAM 3”
