When I run the attached drawing with the CAM function I end up with two contours as you can see in the log. Normally this is ok with a standard gcode.js. If I try to set the start at the other end with my own config I get some unpredictable results.
The problem I see is in the appendtocontour function in CamExporter.js.
srl
Two contours in open contour
Re: Two contours in open contour
Here is a better and more simple example.
srl
srl
Looks like the example in the last post is ok.
Here is another one.
Looking at CamExporter.js I can't see the
while (this.prependToContour(contour)); line being successful at all ?
srl
srl
I found the problem in CamExporter.
The prependToContour function needs to return a value.
srl
Myconfig.prototype.prependToContour = function(contour) {
return this.appendToContour(contour, true);
Great, thanks for posting the outcome. Unfortunately, I didn't have time to look into this, but I did read along..
