Export to HPGL or HPGL2
trongdong
Post by trongdong » Mon Jan 12, 2015 8:09 am
Hey there,
I'm going to use QCAD 3 CAM add-on to export DXF to PLT and bring it to the plotter.
I saw that we can export to G-Code, can we export to HPGL or HPGL2 as well?
If so, how can I do it?
Thank you very much!
Re: Export to HPGL or HPGL2
Post by andrew » Mon Jan 12, 2015 3:14 pm
I haven't done much with HP/GL yet, but here's an initial, very simple configuration you could use as a base for your own, derived configuration.
To use this configuration, simply save the attached file into scripts/Cam/CamConfigurations of your QCAD/CAM installation.
HPGL.js
(5.4 KiB) Downloaded 643 times
Return to “QCAD/CAM”
