Line type and camexport.js requests.
srl
Post by srl » Sun Feb 08, 2015 7:21 am
Hi Andrew
It would be good if we had the line types in the attached drawing which are a variation of "drainage". They could be used to show offset cutting in the CAM preview document.
I've made a small change to createLayer to set line types. Changes are marked with // .
Codesrl.prototype.createLayer = function(layerName, color, lineType) {//
	if (lineType == null)//
		lineType = "continuous";//
    var layerId = this.newDocument.getLayerId(layerName);
    if (layerId!==RObject.INVALID_ID) {
        return layerId;
    var layer = new RLayer(
        this.newDocument,
        layerName,
        false, false,
        color,
        this.newDocument.getLinetypeId(lineType),//
        RLineweight.Weight000
    var op = new RAddObjectOperation(layer);
    this.newDocumentInterface.applyOperation(op);
    return this.newDocument.getLayerId(layerName);
srl
offsetlines.dxf
(104.77 KiB) Downloaded 630 times
srl
Re: Line type and camexport.js requests.
Post by srl » Mon Feb 09, 2015 4:10 am
Sorry Andrew
I did a Google search and found this-
viewtopic.php?f=47&t=3136
I can make some -->--g41-->--
srl
srl
Post by srl » Sun Mar 08, 2015 6:12 am
I got the line types working in the CAM preview for offset cutting.
Screenshot 2015-03-07 14.54.38.png (25.29 KiB) Viewed 13120 times
As you can see I now have arc in and out mid entity working thanks to the added (first and last entity)functions a few versions back. Ramp in arc is green and ramp out is red. Offset starts along the green arc and finishes after the red at the rapid. Later I might add zero moves to make it technically correct.
I can initialise the global widgets, but is it possible to put extra values in the orientation and ramp drop downs from my configuration file ?
Having 'climb cut' and 'normal cut' in forced orientation I could have the inner contours do automatic reverse direction like above, better values in the ramp drop down would set the diameter of the arc, at the moment its all done in layer names.
srl
srl
Post by srl » Thu Apr 06, 2017 9:52 am
Here is my latest config. It uses settings in the dialog as the main default. I did this one about a year ago but have only just lately had the time to use it to cut stuff out.
Best to get it out before the the official one. e_geek
srl
Srlfoamies.js
(28.84 KiB) Downloaded 569 times
GCodeLayerextras.ui
(2.58 KiB) Downloaded 614 times
GCodeextras.ui
(6.2 KiB) Downloaded 545 times
srl
Post by srl » Fri Apr 28, 2017 2:44 am
Here is my latest with a youtube.
Srlfoamies.js
(32.2 KiB) Downloaded 766 times
GCodeextras.ui
(6.2 KiB) Downloaded 795 times
GCodeLayerextras.ui
(2.58 KiB) Downloaded 809 times
https://youtu.be/ALZbLdQpSc4
srl
Return to “QCAD/CAM”
