Complex Linetypes in CAM Output
srl
Post by srl » Fri Mar 13, 2015 6:49 am
HI Andrew
Now I have a problem with the [CAM] screen in 3.9. as well as new untitled screens.
All the extra linetypes are missing in the propery editor. All is fine in the main screen beside it that produced it.But it was saved from 3.8- I tried all the view options.
Colours still work with my config file just none of my special offset lines. :cry:
linux 64. also with gcode.js
srl
Re: Complex Linetypes in CAM Output
Post by andrew » Fri Mar 13, 2015 12:44 pm
srl
Post by srl » Mon Mar 16, 2015 5:59 am
Thanks Andrew
All working again..
Produced from this drawing.
On the Sim
Here is the Gcode
ramp.ngc
(2.38 KiB) Downloaded 614 times
ramp.ngc
Still testing my config.
srl
Return to “QCAD/CAM”
