I just recently downloaded QCAD and was fallowing a tutorial and discovered I don't seem to have a Library Browser widget.
I have uninstalled and re installed the program twice, the second time with a new download from the QCAD site, Iv also made sure I deleted the old QCAD Program file folder before each new install. Not sure what else to do besides ask, entirely possible that I'm being obtuse and just need to be lead to water. Thanks for any help.
I'm ruining an old HP Laptop W/ Windows 7- 32 bit, using QCAD 3.28.1
[solved]Library Browser
- QCAD_205719.pdf
- (898.13 KiB) Downloaded 245 times
Re: Library Browser
I apologize I miss labeled my operating system it is Running Windows 7 64 bit
Re: Library Browser
you posted your question below Qcad Profesional but I'm pretty confident to say that you are running the Community Edition, correct?
Please note - the Community Edition retired short time ago the Library Browser. From now on this widget will only be available within the Professional version.
Re: Library Browser
Work-around:
https://www.qcad.org/rsforum/viewtopic.php?f=76&t=9948
Please note the remark on inserting Script-Items by Andrew.
Re: [solved]Library Browser
Thank You for your time
