Hi all, I am a beginner to cad drawing and I just cannot finger out how to change the yellow color blocks to black or other dark color
the yellow color is so bright and not visible when print out
Thanks a lot if you can help me!
Need help! I cannot change the color of the yellow blocks
- st sanitary updated.dwg
- (2.23 MiB) Downloaded 143 times
- st plumbing updated.dwg
- (2.23 MiB) Downloaded 145 times
Re: Need help! I cannot change the color of the yellow blocks
Unfortunately, the color of these entities has been set to "yellow" (as a fixed color) rather than being defined by layer as is recommended.
This means that what normally would take a few clicks would now be a major effort: You'd have to change all these blocks manually.
Perhaps, you can resort to printing in black / white of greyscale instead:
Edit > Drawing Preferences > Printing > Colors > Black / White or Grayscale
