Part library refresh
venkatkoka
Postby venkatkoka » Tue Sep 14, 2010 12:37 pm
I have created some sample drawings which were sorted according to the drawing type and saved in different folders. And the path of the main folder is given in the "Application settings" -> "Paths" -> "Part library" path. It has worked very well for the first time. And meanwhile after discussing with a colleague we had to delete some folders and add some more. But the "Library browser" in QCAD shows all the folders that were deleted including the newly added. Can we some how refresh the folders list so that only the folders that were actually present in the path would be shown up?
It would be a great help if you can help me through this.
Thanks,
Venkat
venkatkoka
Postby venkatkoka » Tue Jan 11, 2011 3:07 pm
The soultion found until now was to re-install QCAD and all the folders from the given path will be refreshed i.e., only the folders that are presently will be shown.
Regards
Venkat
Return to “Chat”
