What do people use QCAD for?
J-J
Moderator
Re: What do people use QCAD for?
Postby J-J » Fri Mar 14, 2014 10:26 pm
News on the second hybrid passenger boat: Launched and left the berth on electric power. Max speed close to 7 kts under two 12 kW motors.
Enjoy the pictures.
JJ
Postby Clive » Fri Mar 14, 2014 10:34 pm
Hey J-J, thanks, that really is something. I could see myself sitting in one of those chairs on deck, ready for a light cruise 8) .
kazmer
Postby kazmer » Wed Jun 18, 2014 11:56 pm
I am using QCAD mostly to create floorplans vis-a-vis the electrical bits (wiring and the like) of a building. Not too long ago, when a friend moved in a new rent, we have used QCAD very extensively to plan the space for furniture and things (that is, she commandeered and I did the eye-rolling bit). It was invaluable help, probably saving her a lot of frustration and me a lot of extra work.
There's always the little mechanical design things too, and sometimes just the general goofing around, just for fun and trying things out - you never know when will it come handy :).
linnemann
Postby linnemann » Thu Sep 04, 2014 8:40 pm
Pro version here.
Using i primarily for plant installation drawings and also for cleaning up dxf files for cutting with laser or plasma cutters.
Also great for prototyping before going 3D.
We also have Autocad, but I rarely use it, it has become too bloated for a 2D Cad tool IMO.
2014-09-04 21_38_19-Cyklon (ID 4019).dwg - QCAD.png (11.32 KiB) Viewed 3882 times
2014-09-04 21_37_32-25024 Arr (ID 3018).dwg _ - QCAD.png (31.97 KiB) Viewed 3882 times
smf
Postby smf » Sat Dec 13, 2014 9:37 am
Hi there,
in the meantime I now use QCad Pro also for model railroad track planning and there wrote some scripts (with help of Andrew, thank you). See
viewtopic.php?f=32&t=3171
for the current work-in-progress state.
Märklin H0 C-track example:
model railroad track planning example
Return to “Chat”
