PDF to DXF/DWG converter ....
Postby Husky » Sat Jan 25, 2014 7:05 pm
Hi everybody,
I'm in need to use a PDF to DXF/DWG converter and I'm looking for a Free OpenSource Software to get it done.
There are a couple (good!) converter out there - but they are asking for a lot of money.
Maybe somebody has experience with a Freeware converter and like to share the source .... e_surprised
... or maybe there is a way to implement something like that in QCAD. :wink: :wink: 8)
Re: PDF to DXF/DWG converter ....
Postby Clive » Sun Jan 26, 2014 1:14 pm
Hi Husky
You may be able to do this in Inkscape,pdf to dxf or pdf to svg first ?
Moderator / Drawing Help
Postby Husky » Wed Jan 29, 2014 9:07 am
Hi Clive - it works better than I thought with Inkscape. Thanks for the hint.
You have just to open the PDF in Inkscape and save it then as a dxf. Open it in QCAD - check the scale - if necessary fix it - done!
Thank you!
Return to Chat
