modification tool set?
lancerman
Post by lancerman » Fri Jul 11, 2014 10:18 pm
I'm new to cad and going through the q cad book. I can't find the edit button on page 50 to extend symmetry lines. Is there an add on called a "modification tool set"? or...
Also wondering if the /CAM was an option I missed or if it is an additional cost item.
Re: modification tool set?
Post by andrew » Sun Jul 13, 2014 8:52 pm
Please check that you are using an up to date version of QCAD (3.x).
You can check your QCAD version under Help > About (Windows, Linux) or QCAD > About QCAD (Mac).
Screen Shot 2014-07-13 at 22.06.03.png (96.38 KiB) Viewed 7335 times
Please indicate also what operating system you are using (Windows, Mac, Linux), so we can help you most efficiently. Thanks.
QCAD/CAM is a separate product which consists of QCAD Professional with a CAM add-on:
http://www.ribbonsoft.com/shop/product. ... roduct=193
lancerman
Post by lancerman » Mon Jul 14, 2014 6:51 pm
Thanks Andrew,
The new book was changed and had my answer. I also updated my version. very helpful.
Lance
Return to “Chat”
