P&ID Symbol quantities
DACAD
Post by DACAD » Fri Oct 09, 2015 5:01 pm
Hi there
I was trying to figure out how to identify the symbol quantities on a P&ID in a simple way, without counting & marking it on a paper.
Does someone knows a function or an automated way in QCAD, which allows me to identify the quantity of a certain symbol from the library (valve, instrument, etc.) on the P&ID?
Appreciate your help, regards,
Ben
Re: P&ID Symbol quantities
Post by andrew » Fri Oct 09, 2015 5:36 pm
Misc > Block > Export Block List might be a solution. It exports the block list with a block count to a tab separated csv file.
Return to “Chat”
