Count
piupiu
Count
Post by piupiu » Wed Jun 08, 2016 12:37 am
May I know if QCAD has the capability of counting number of objects or lines?
Let say I draw a few circles of different diameter and lines of different length and color.
Is QCAD able to do a count for me of each circle & lines?
Re: Count
Post by Husky » Wed Jun 08, 2016 1:30 am
Hi piupiu - welcome to the forum.
piupiu wrote:Hi,
Yes, QCAD is able to do that for you.
Launch the Property Manager (Menu/View/Toolbars and Widgets/Widgets/Property Manager),
Make a selection of the entities which needs to be counted - and check the info in the property manager below Selection ...
If you need to have more control over what has to be selected - use the "Selection Filter"
and read again the result in the "Property Manager".
piupiu
Re: Count
Post by piupiu » Wed Jun 08, 2016 1:37 am
great, does this counting capability available from the free version?
Re: Count
Post by Husky » Wed Jun 08, 2016 2:22 am
piupiu wrote:great, does this counting capability available from the free version?
Property Editor - yes.
Selection Filter - no.
To compare the Free with the Pro check out this page:
http://www.qcad.org/en/qcad-documentation/qcad-features
Return to “Chat”
