QCAD Pro Not Installing on iMac
Jay Dee
Post by Jay Dee » Fri Apr 14, 2023 5:07 pm
I just purchased QCAD Pro after using the free trial for a few hours. I completely deleted the trial version and installed the Pro Version, but some tools still locked out, just like trial version had. Please help.
Thanks!!
Re: QCAD Pro Not Installing on iMac
Post by andrew » Fri Apr 14, 2023 5:19 pm
Note that some menus (tools) require a selection (for example Modify > Move / Copy, Modify > Rotate, Edit > Copy, etc.).
Please refer also to the user manual of these tools:
https://qcad.org/doc/qcad/latest/reference/en/
If you cannot solve the problem, please indicate which tool(s) exactly you are referring to.
Jay Dee
Post by Jay Dee » Fri Apr 14, 2023 5:45 pm
Fixed by re-installing again. ?? Thanks !!
Return to “Chat”
